S21 FE 5G NETWORK SOUND
(Topic created on: 02-21-2023 09:57 PM)
Saransh1831
Can anyone confirm me if they hear a sound from the front part of their phone while using 5G data. Like this area of the phone top front area please confirm me and try to listen carefully in a quiet place while using 5G mobile data if it is so tell me.
MonK11
I would like to ask you if your phone heats up abnormally like really hot when the sound is coming.
Saransh1831
no i mean it's like signal sound only but comes only when using 5g even if the phone is not hot does it comes from your phone also?
MonK11
Not it doesn't comes from my phone it it should not be coming out of your phone as well.
From my personal experience with a Nokia phone long time ago I was hearing a faint bipping noise coming out of the phone. It turned out to be a short circuit in the phone.
Saransh1831
it's sounds like kit kit kit...buzzz..... this type
MonK11
No I can hear no such sound.
Saransh1831
what should i do now?
MonK11
As I said earlier go to the service centre or you can use your phone as youre using if the noise isn't bothering you too much
Saransh1831
they checked for the hardware issue there wasn't any...
MonK11
Then use it as you're doing.
Saransh1831
it only happens while using 5g data the sound is like gizzz gizzz gizzzz
