s21 FE crackling sound on 5g network
(Topic created on: 02-12-2023 09:53 PM)
Saransh1831
Is anyone experiencing crackling sound effect at the top front of the phone after January update while using 5G network.
16 Comments
You mean while calling?
Saransh1831
Yes and normally also while on 5g network only
I have faced the same issue sometimes while calling but not normally
Saransh1831
From when are you facing?
After I started using 5g
Saransh1831
did u visit a service center?
No but in you case you may need to visit the service center
Saransh1831
Does it makes a buzzing sound like somehwere on the top of the screen and how did u resolve it?
No the sound was from the earpiece due to bad connectivity.
