S20fe 5g Battery Replace?
(Topic created on: 05-02-2024 11:07 PM)
tusharkabir
After 3 year my battery capacity showing 3400mah in accu battery health.
Should I replace this battery soon or keep running on same capacity.
9 Comments
Sayan_SS_
You Can Check Your Battery 🔋 Condition Through Samsung Member...To Check Follow This Steps:-
Open Samsung Member→Support→Diagonostics→Battery→Check From There That Will You Have To Replace Or Not.If It's Written Action Required You Will Need To Change Otherwise Not.
If It's Helpful For You Please Consider it As Sollution 😊
By Clicking On Three Dot Present Above This Comment→Click On Accept Sollution
tusharkabir
Battery issue detected .
Life : weak
Sayan_SS_
Then You Will Have To Replace The Battery 🔋
Please Make That Comment Sollution By Clicking On Three Dot Present Above That Comment→Click On Accept Sollution
tusharkabir
what if I run my phone on this condition? anything harmful?
BearXXV
You will not get the battery backup like you used to. Degraded battery must be replaced for your own safety. It might or might not be dangerous to use it like that. There's no guarantee that it is harmful but there's no guarantee that it is safe either. If I were you I would replace the battery with a genuine one as soon as I can. It depends on your judgement.
iamrohitkm
Visit the service center once and ask them to check the battery. They will check through some of their tools, and if required, they will ask you to replace. Don't depend on apps.
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that you can also check the battery health using the Samsung Members app, Battery Status (Battery life + Battery Capacity). if it shows bad or weak then you have to visit the service center, else it is showing normal there is no need to worry.
If the diagnosis result is poor, please visit the Samsung Service Center with the device for future assistance. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
tusharkabir
Does they charge only for checking battery ?
paogoulamkipgen
Beginner Level 3
Battery issue Detected
Live:Weak
Capacity:4500 mAh(Typical)
