04-03-2021 03:14 AM in
Galaxy S- Mark as New
04-03-2021 03:30 AM in
12-13-2021 06:28 PM in
04-03-2021 05:27 AM in
Galaxy Seven you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
04-03-2021 05:28 AM in
Galaxy S3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info (ibutton> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
04-03-2021 12:16 PM in
04-03-2021 03:48 PM in
04-03-2021 09:37 AM (Last edited 04-03-2021 09:38 AM ) in
Galaxy SI agree to some of your points but I am not completely aligned to all of your suggestions
That is to disable almost everything then instead of doing that we will turn off mobile when not in use that gives super battery life.
Please bro with same settings enabled on other manufacturers is giving better battery life than Samsung devices now say where is the issue
04-03-2021 03:50 PM in
04-03-2021 05:39 PM in
Galaxy SI had already done those settings which you suggested and I am aware of all these as I don't have an option other than to do so on my s20 plus as battery is not upto the mark.
My point is I do have another mobile where Almost same settings which are suggested here to turn off are enabled and getting a better life when compared especially idle time.
And one more thing I mentioned multiple times in the community don't expect end user to have knowledge on all the settings and even if the person have knowledge also its not good experience to make ppl to thoroughly check these things and take action accordingly why we would/should someone invest so much time on checking this
