S24 Ultra Bugs And Hitting Problems
(Topic created on: a week ago)
imuk
@Samsung After Getting One Ui 7 Beta Program Ends Update It's Seems Lots Of Bugs And Battery Drain And Hitting Issue.
Please Look Into This And Provide 1 More Hot Fix Update To Fix This Issue.
In Quick Settings Panal
8 Comments
Slundermist
In May, there would be an update to further stabilize
imuk
Hope So
Slundermist
There will be
S_Kumar73
Hitting???
imuk
Yes
NOMAĐ
He means heating
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
In case the issue still occurs and regarding bugs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
