S20 fe charging port issue
(Topic created on: 12-26-2024 10:16 PM)
vetz
How much does it cost to replace the charging port for Galaxy s20 fe 5g ? Currently facing battery life :weak in the diagonistic center as well
9 Comments
Did you have warranty?
vetz
No..
May be under 2 thousand or less than ...
vetz
Ok
Battery cost Rs 1,770
vetz
Ya I could see that in spare part list . But couldn't find anything for chargin port cost . Hence want to know
Wodehouse
Visit a service centre. They are the best people to give cost estimate.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
cs_member10
Dear Samsung Member,
As per your query, we kindly request you to visit the service centre where our technical team will inspect your device. They will provide you with all the necessary information regarding the charging port replacement cost after a physical examination of the device.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
