S20 Fe exynos battery drain
(Topic created on: 08-26-2021 06:33 AM)
S20FeEXYNOS
Beginner Level 3
Hello community members,
I am using S20 fe exynos 990 version that was bought in March 2021 with 8/256 configuration.
I am facing very high battery drain and max SOT is around 3-3.5 hours .
Is this normal or some settings are at fault?
It is running Android 11 with latest August security patch and One UI 3.2
16 Comments
Edwin7878
Bro this is due to the exynos chipset on S20fe 4g version ..
Not normal.
Samsung is not capable of optimizing its on exynos chipsets to reduce the issues in it to some extent
S20FeEXYNOS
Beginner Level 3
So is there any fix that I can apply?
Edwin7878
Can't do much about it ..
But can be improved to some extent ..
If possible reset ur phone and take backup of all ur data before resetting..
Then too no change means visit service center and tell them to reinstall the software ..
AlphaTrion
Exynos 990 is the worst chip failure of samsung. It lacks efficiency by a large amount.
Abpal
That's why they ditched mongoose cores
AlphaTrion
It was their own work.
Ditched it too late, after almost 5 years, spoiled 5 years of their flagship.
Abpal
Their current flagship, s21 series, is better than earlier.
AlphaTrion
Better ?
No charger.
No SpO2 sensor(heart rate/oxygen level).
No MicroSD card.
No headphone jack.
No WQHD+ display on base S21 and S21+ variant.
Design is not slim and sleeky.
Just because S21 lineup has 120hz and better processor doesnt mean its better than Snapdragon S9+ and S10+. Lacks so many other stuff they used to give before.
Abpal
So, which company give spO2, and headphone jack ?
Even, iphone doesn't provide charger
Lol!!🤣
And, I am talking about primary things in which s21 is better like camera, processor, and battery.
