S20 Fe 5g back panel / battery swelling
(Topic created on: 10-02-2022 10:08 AM)
S20_fe_5G
The back of my 1.5 year old S20Fe 5g suddenly came out . Firstly a little gap was there so i was trying investigate whether the battery was swollen or not from the outside while the back panel was still there . I found a little gap between the panels so i just pressed it then the whole back panel just fell off but the glue was still there. I felt The battery was swollen a little bit maybe😕 and also Since last week the battery backup was too bad 👎 . Now Scared to use the phone if the battery bursts 🥲
Just want to check if other users have the same problem .
Samsung Flagships ~ A great disappointment 😞
25 Comments
San740
Is samsung replacing the battery for free or there is charge for that
S20_fe_5G
Nope i guess
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
god7slayer
Hey bud!
Did you notice anything else leading up to the swelling? Like over heating or perhaps restarting on its own? Anything like that?
S20_fe_5G
No i didn't notice anything as you mentioned but a slight overheating... went to samsung service centre got my device checked .... they told me that only back case glue was the problem it cost me ₹680 for new seal .... no battery swelling nothing ...till now phone is good
god7slayer
That's good to hear man. Glad everything is sorted out
