S20 Fe 5g back panel / battery swelling
(Topic created on: 10-02-2022 10:08 AM)
S20_fe_5G
The back of my 1.5 year old S20Fe 5g suddenly came out . Firstly a little gap was there so i was trying investigate whether the battery was swollen or not from the outside while the back panel was still there . I found a little gap between the panels so i just pressed it then the whole back panel just fell off but the glue was still there. I felt The battery was swollen a little bit maybe😕 and also Since last week the battery backup was too bad 👎 . Now Scared to use the phone if the battery bursts 🥲
Just want to check if other users have the same problem .
Samsung Flagships ~ A great disappointment 😞
Kunal2
Already there are many users facing this issue. Lots of posts regarding this back panel coming out. Just search 'back panel' in community n see results
S20_fe_5G
P🥲
Sáyân15
My battery is absolutely fine...
No issues
SrajTech
That's strange
Visit service center and see what they say
Problem99
Bro my a52 4g has the same problem too and it's just 1.2 months old.
S20_fe_5G
There's nothing to do about it i guess
Problem99
Although samsung has one of the best UI and models but they will lose a lot of customer pretty soon if they continue manufacturing cheap build quality. Anything above 26k deserves a glass back or a good plastic back .
abbishek091
Bro its just becauseof the glue become soft due to samsung heating device like yours s20 fe 5g and your back panel then popup
S20_fe_5G
Theres another problem , my sim cards stopped working suddenly and sometimes it does works after restart but then after some time its the same🤷‍♂️...
abdulheera
I have also same battery drain problem ,buy mobile for using not for charging 2 time in a day that's why I return my galaxy s20 fe within 5 days ,salute to Samsung they still save their no 1 positions for battery backup problems,
