S10+, Waterproofing after battery replacement
(Topic created on: 09-11-2021 10:48 PM)
karandriems
Guys, waterproofing will be there after the battery replacement in S10 plus from the authorities service center??
Actually i want to change the battery but scaring waterproofing will be no kore after battery replacement.
6 Comments
Anikroyale
Your phone was never waterproof. No phone in this world exists which is waterproof. Your device is rated as IP68 water-resistant. Water-resistant and waterproof are completely different things.
Now to answer your question, yes, water-resistance will still be there even after battery replacement.
Pro tip: never expect water-resistance to protect your device from water damage. Not even on a brand new device.
karandriems
Waterproofing i mean IP 68 only. Not completely waterproof.
karandriems
Ohkk thank you bhai
siva9101984
No problem. Authorized service center can make it perfect. After replacing battery they run water test and then deliver to you
Aashish
Expert Level 4
You can check water resistance after battery change using this app
https://play.google.com/store/apps/details?id=com.ray.waterresistancetester
Dear Samsung Member,
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurred.
