Resolved! Solved
Rwgarding facing problem in AUTO HOTSPOT feature
(Topic created on: 04-15-2024 03:32 PM)
DrAtharvaSharma
After the Update of my New UI 6.1 my Tab cannot search for auto hotspot. My Auto Hotspot feature in mobile turns off automatically as soon as I turn on my wifi in Tab.
It repeatedly turns off on trying it to turn on.It remained ON(when I leave it ON) untill Wifi of my Tab is turned On. There is no error message shown on my tab or mobile.
Using Tab S7 FE and S23 FE
2 Solutions
_Jatin_
Samsung acknowledged this problem and said it will be fixed in next update
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
12 Comments
_Jatin_
How did you Know, Sir!
_Jatin_
The first problem can be fixed in tablet wifi》intelligent wifi》auto hotspot and use what you like
Sir I tried it
goodthings
How do I Send Log Files
goodthings
It's automatically send by system after send error report immediately. But don't close Samsung Members App during this process till complete. Thanks.
cs_member10
Dear Samsung Member,
Disable the data saver:
Path: Settings > Connections >Data usage > Data saver > Disable data saver (if enabled).
Reset network settings:
Path: Settings > General Management > Reset > Reset network settings.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
I have done these troubleshooting steps already and sent log files
