Resolved! Solved
Rwgarding facing problem in AUTO HOTSPOT feature
(Topic created on: 04-15-2024 03:32 PM)
DrAtharvaSharma
After the Update of my New UI 6.1 my Tab cannot search for auto hotspot. My Auto Hotspot feature in mobile turns off automatically as soon as I turn on my wifi in Tab.
It repeatedly turns off on trying it to turn on.It remained ON(when I leave it ON) untill Wifi of my Tab is turned On. There is no error message shown on my tab or mobile.
Using Tab S7 FE and S23 FE
Resolved!
12 Comments
Ryuzakikun
This issue still persists. There is no fix till date. What's even the point of advertising the samsung ecosystem then?
vjfhcfj
Process failed problems
Hybridpriest
Got the same issue, Contacted the customer support, Done all the reset, Still the issue exist! Waiting for the next update 🫠🥲😞😏
