Rear view camera not working with whatsapp video calls in S24+
(Topic created on: 06-23-2025 01:25 AM)
Sak08
During whatsapp video call, unable to switch to rear view camera from front camera mode. While, the rear camera is working with other apps. I have cleared the cache, uninstalled and installed whatsapp again but the same issue persists. Could you please help. The call stucks on doing so.
Checked with whatsapp, it is not their issue, working with rest models only Samsung S series facing it.
Please fix it, it is one of the basic functionality. This happened recently.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Sak08
I have already shared the log info last evening from your Error section in Members support.
I would appreciate if Samsung can fix this at the earliest.
gravitysucks
same here.. camera issue.. when.inused blackmagic app it works but camera it fails
jjb34
Same here
Tpo88
Beginner Level 3
Hi man, I've just found a solution for this issue. I also have this device, and I was facing the same problem. I figured out when I try to add an effect (magic stick logo) like touch up for example (mask logo), the rear camera works perfectly on WhatsApp video calls. The best part of it is that in the next video calls, WhatsApp will remember this so you don't have to switch this effect again. I believe it's a glitch of the app which will be fixed completely in the next versions.
Sak08
How did you do it?
Can you guide me with the steps
Tan_Veer
Beginner Level 3
This method work for me. But still this is not a solution.
Sak08
Finally, it got fixed. I recieved an upgrade 2 days back and post that it works fine now.
KrishhDev
I have this issue after recent update. Camera gets stuck when you try to flip it during a call
SujataG
Same issue. Bought S24 just a day before. Configured whatsapp today and very disappointed to see back camera not working on video call on whatsapp.
More disappointing that this problem is faced by many users but no solution from samsung
