Resolved! Solved
REGARDING S23 ULTRA CHARGER
(Topic created on: 12-21-2024 12:29 PM)
Imkatna
Hi, everyone I just wanted to know that if I can use vivo charger for my S23 ULTRA
OR it required samsung charger to use if it impact the overall charging performance of the smartphone or not, please help me to know this so I can buy a new chart
5 Solutions
iamSUHAIL
Use samsung compatible charger for better battery life.
If you are using other brand charger then Super fast Charging will not work and also can be harmful for your device if you are doing same thing till long time.
iamSUHAIL
I suggest you to buy from their service center or their official website. Please don't go for another website and shop most of them are doing frauds. My opinion is that go to samsung store or their service center.
jay626
Buy it from amazon
BennySolo
Samsung Charger is Best....Buy Amazon
rhlkatare
Always charge your device with the brands official charge.
Using other brands charger can also void warranty and cause problem to the device also.
Buy it directly from Samsung website or either their Service Center or Official Store.
You can buy also from online platforms like Amazons but please check and verify the seller before doing that so.
Thanks.
12 Comments
iamSUHAIL
Imkatna
Where to buy?
iamSUHAIL
Imkatna
Ok
jay626
Buy it from amazon
Imkatna
Ok
BennySolo
Imkatna
Ok
Imkatna
Thanks everyone 🔥🙏
