Quick Share Problem in s21fe (888)
(Topic created on: 02-19-2024 05:33 PM)
Somnath16
I am using Samsung Galaxy S21fe. (888). After one ui 6.0 update I am facing many bug issues. But after February 1 2024 security update Quick share started occured problem.
After update, I can send any file or videos with other phone through Quick share easily but I can't receive any. When other person try to send me any file or video, it's started it's problem. First of all if someone sending me any data or anything, it's receiving the same by 2 notification and as 2 file and both are same. Due to this transfer become slow automatically. What is the problem.
I have tried every step for reset settings and every thing, but the problem is intact, no changes there.
18 Comments
Dhammiin
Restart you phone in safe mode first and then try
Somnath16
Dhammiin
Go to quick share settings and check the option who can share with you . Switch it to everyone
Somnath16
Already done...nothing changes
Dhammiin
What was there in the quick share settings?
Somnath16
rakibhosain
S20fe one ui 6.0 update
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share the same video clips and images for better understanding. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Somnath16
Already sent... and here is the reply.....
