Calling all S21Fe users to share their current device problems
(Topic created on: 07-22-2024 08:24 PM)
MrGEEK
Hey S21Fe users,
I am back to collate all the issues which you are facing with S21Fe.
Please help me by sharing your issues so that, I can share it with the team.
25 Comments
AGalaxyuser
Currently I'm not facing any issues with my S21fe SD888. I didn't updated mine to latest security patch. Also a normal user. Only one problem I face sometimes once in a while my lock screen flashes for a micro second when I try to unlock my phone by double tap to wake up.
Pranav122002
Thats a feature called increase brightness temporarily for better face detection in dark places. You can disable it in settings
AGalaxyuser
I know that feature and it's disabled.
Oh strange, I never faced any such problem. But thanks for mentioning, will share this with team.
AGalaxyuser
After researching I found one thing that is I mostly use my phone in power saving mode and 60hz also disabled fingerprint always on from biometrics. After power saving off and fingerprint always on I'm not facing such issues. I saw this problem is happening cz of optical fingerprint scanner. Ultrasonic scanner devices don't have this problem. Maybe a bug. However after doing this settings I'm not facing any problem so far.
Okay 🤔
AGalaxyuser
This issue was previously reported by some S20fe and A52 users in this community.
AGalaxyuser
Did you also facing same issue? I read some article where the main reason behind this problem is under display optical fingerprint sensor.
SupriyoDutta
Im using S21 FE Exynos version... after the june 24 update my battery is draining super fast.. on standby with all the connectivity off and power saving on my phone consuming 40 to 45 % at night.. i have to charge it every 3 to 3 and half hour.. cant even take it outside with me now...and im not a heavy user just some social media scroll never installed any games...and battery health is in good condition
