Call problem
(Topic created on: 10-16-2025 09:01 PM)
sazidislam
My s24 one ui8 update ,i can not recive call,call ar not coming and i can not call other.plz help
6 Comments
Vj42
Reset all setting once
Vj42
Check in safe mode
Back up your data and visit service center, we will do software update (stable one)the issue will resolve easily
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
