Quick Panel and Power Menu on Lock Screen
(Topic created on: 10-30-2023 02:25 PM)
Rohith_Pillalamarri
Please implement the toggle to Disable QuickSettings Panel and Power Menu on Lock Screen for security reasons.
Anyone can just swipe down the QS panel and launch power menu to turn off the device...
Force reboot can be done manually through buttons, but it comes back to the system again, instead of staying power off
So as a security part -- please implement the toggle to disable Qs panel and power menu on lockscreen
5 Comments
Devv_007
Which phone?
And check if this thing is enabled in it.Screenshot_20231030_144311_Settings.jpg
QS Panel and PowerMenu is not accessible fof you on LockScreen ?
The thing you pointed out ,only prevent user from turning off mobile data and wifi
Devv_007
No, it asks for pin before powering or restarting it if this option is enabled.
It works on s23.Which phone you are talking about?
Did you actually check it ?
Iam on S23U , and there is no prompt for password , its ditectly rebooting and powering off
After enabling lockdown option toggle, there is a prompt for password
Devv_007
Yes,I checked it, it only works if this option is enabled.
Also works if lockdown option is disabled for me.
