Process system isn't responding facing s 22 ultra
(Topic created on: 08-09-2024 01:28 PM)
akshaypatole
Beginner Level 3
I'm facing the sum technical issues during the use of WhatsApp . Like process system isn't responding. Slow working.
Disable volume button commands
And heating smartphone
4 Comments
cs_member10
Dear Samsung Member,
As you are facing multiple issues on your device, kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
akshaypatole
Beginner Level 3
Members_jDWFEFQ
Beginner Level 3
same
Members_jDWFEFQ
Beginner Level 3
Disable volume button commands on using whatsapp
 phone is very slow nearly
all apps are slow
