Problems with galaxy devices as of April 2024
(Topic created on: 04-13-2024 10:01 AM)
snacharya
As of April 2024,
several issues with samsung phones, including:
  • Galaxy S24 Ultra
    Some users have reported white balance and overexposure problems, abnormal red colors in the camera, and issues with telephoto imagery
  • Galaxy S23
    Some users have reported issues with charging and fingerprint scanners after installing the update
  • Galaxy A53 5G
    Some users have reported a stretchy image problem after the December update
  • Galaxy A54
    Some users have reported heating, battery drainage, and lag
To avoid these bugs don't just update your phone immediately , wait for a bit and let us test the updates and if we face the same problem we will inform you asap .
For any query you can have your question in the comment section .
I hope this info helps
8 Comments
vivek1989
U missed s23 fe 5g
snacharya
Yes , you may add it but somehow no such visible problems found with that device in a huge number .
But thanks for informing
vivek1989
Battery issue and heating prblm bro it has
snacharya
Being a compact phone it's really hard to manage the heating department ...
But smasung had tried to manage it as much they can , because with such small surface it's really hard to manage the heat efficiently ...
With further updates it will go good .
And yes about the battery ,
First take a diagnostic test of your battery , then Reset the dumpset of battery , restart your phone and charge it 100% with the original charger . You'll have a better back up .
I hope this helps
Subhro99
Currently using A54 5G
Ejaj786
Slow charging and charging not update after 78 %
snacharya
Try to drain out your device's battery and then restart it before charging...
The charge it
You'll have noticeable difference
ggaam
Mu s22 ultra display problem happen after updates
