Problems after upgrading to Android 12 in S10 +
(Topic created on: 01-22-2022 12:02 PM)
Indervedi
I have been facing multiple issues post upgrading my S10+ to Android 12 / One UI 4. Seeme like Samsung messed up the upgrade.
1. Battery drains much faster now.
2. Not able to install apps from Play Store. I have already checked for latest version of Play Store and it is there.
3. Pics clicked with WhatsApp camera are shifting to left.
4. Whenever I restart the phone it and me to uninstall VR apps. If i do that, Facebook gets uninstalled. So does Instagram.
5. Alexa app not getting installed.
6. Adaptive brightness does not fun the screen enough in dark room.
I am sure there will be more bugs. Honestly, this is the first time I have come across such issues post upgrading and i feel Samsung messed it trying to bring in the update in a hurry.
How there are some resolutions absolve to the issues. If yes, please share. Just don't tell me to reset my phone or delete any accounts. These are the worst resolutions that can be suggested for any problem simply because they entail lots of extra effort around days restoration.
24 Comments
10300
3rd problem is even faced by me in my m30s
10300
but only a few times
Indervedi
This is only for device freezing
There will be a new software update coming soon with Jan 2022 security update, may be that will fix some bugs
alamayaan234
As I think only solution if waitf for the bugs to get fixed in the next update that's the only possible solution which I can figure out now.If u are in urgency then visit the service center.There are many users telling that they are facing issue after the Android 12 One UI 4 update.
karandriems
You can do the Wipe Cache partitions and check, it might help you
Indervedi
How to do this
karandriems
Turn off phone
Insert power cable /Connect to PC or headphones into USB c port
Turn on phone while holding volume up and power button with bixby button (if its there) and wait till you see menu.
Scroll down to wipe cache partition using volume down button.
Select using power button, then reboot system.
Note-Wipe cache partition only carefully.
