Problem with WhatsApp in dual messanger
(Topic created on: 10-25-2019 09:08 AM)
nomad_manjeet
I can't see contact in WhatsApp in dual messenger.  Saved name didn't displayed only contact number displayed.
3 Comments
Melville
you need to enable the contacts for then to be visible. go to settings -> advanced features -> dual messager . at the very bottom enable the contact selection
Melville
here are the photos for your reference. turn it off if you want to see all contacts in the 2nd whatsapp. turn it on if you want only specific contacts
