Problem with LockStar module in GoodLock
(Topic created on: 06-09-2025 06:24 AM)
demigod029
The lock screen clock widget changes it's size automatically with passing of time. It basically keeps shrinking, every few days I've to resize it to maximum and it shrinks again. Is anyone else facing this issue, any solution?
PS - I'm using S25
5 Comments
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
demigod029
I've tried doing that twice before for some another issue and haven't got any satisfactory response, I've explained my issue very well in the text
demigod029
Also the widget size shrinks over days i can't screen record for that long
elesh2702
I m facing high battery consumption after enabling Good Lock
demigod029
I didn't notice any such issues
