Problem in homescreen note widgets
(Topic created on: 08-12-2025 04:06 PM)
mahtab1900
When ever restart my phone there is blank screen shown on my home screen note widgets. Can anyone facing same issue. I have attached the photo of homescreen. In my s23u
2 Comments
goodthings
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
