Post one ui 7 rapid battery drain
(Topic created on: 04-29-2025 12:31 PM)
liked
Im seeing 90 89 to 87 percent rapid battery drain in my. S23 after the onenui 7 updated
Samsung please optimize this !!
5 Comments
CipherChip
I had same problem, because of major update ,I performed factory reset.
I did the same, my battery is good now , I charged my phone to 100% today morning at 6AM and now at 12.21pm my battery shows 87%
lf you find this useful, then click on the three dots given above this message and accept it as a solution.
liked
Without factory reset cant we solve this? I cant reset my device
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
