Battery draining issue in S25
(Topic created on: 05-21-2025 10:43 AM)
golo
Hi,
Almost 6 days back I purchased S25. & just started using the phone & am seeing rapid drainage of battery. eg when I charge phone to 100% withing 18 min it comes to 90% and then it goes again down without any heavy usage.
Kindly help & support in this case
Or realise a patch update for same.
5 Comments
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
golo
Yes it's did all the mentioned steps, still facing the issue
golo
Is the phone optimizing the battery according to the usage in initial days & then it will be okay is it like that
rage_knight
Beginner Level 4
That is there but the new update is causing battery drain issues
