Please fix the battery life of s23 ultra
(Topic created on: 07-21-2024 06:57 PM)
Bibine
Samsung please fix the battery life of the s23 ultra. This phone used to be a beast before one ui 6 and is most likely a software issue. The oneplus 12 lasts way longer. I only get about 5 hrs screen on time just by using social media apps. Please fix the battery of this phone instead of adding useless features.
Thank you
5 Comments
Sameer
For battery drain pls refer to the below tips and tricks to enhance battery life
https://youtu.be/DXM7pdW5a-w?si=jPrtDBOtQwYdA3cO
Always make your phone run 2x faster
https://youtu.be/pgNi1Pmua3c?si=BSGl0-4vAexq9BmH
Subscribe to my channel for many more exclusive content coming up....
Bibine
These don't work since it is an issue on the software side due to samsungs poor optimization after some updates
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps in the link below.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
goodthings
goodthings
Your's most welcome to here.
