Pixel buds pro (A) , Samsung buds 2 pro (B)
(Topic created on: 11-09-2023 12:16 AM)
Luck-è
Kindly help me out which ill be good for my device s23ultra !
I ill be using it for gaming , listening music , taking calls most of the times !
And which one supports fast charging and giving a good battery back up , sound clarity , good latency for gaming !
Comment down asap which should i go for and why reason 😵💫 confused ..
10 Comments
GouriPrasad
For gaming never use TWS and for rest go to galaxy buds for better ecosystem
Luck-è
AGAMERZ
B
Luck-è
DarkPhoenix
Hi,
It is a myth that TWS are not for gaming as a lot of buds are launching with very low latency which is optimal for gaming. Other than that, Try buying a Samsung bud as a complete samaung ecosystem really enhances your overall Samsung Experience while you're using it, if your budget allows, go for buds 2 pro to check all the requirements you've asked for. Else the buds 2 and live are also great option in terms of comfort as well.
Hope this helps.
Luck-è
Thank you but i have seen a alot of bad reviews in amazon and flipkart thats why bit cnfused
DarkPhoenix
Don't be confused. Its not a myth that you can't play games on tws due to low latency. Yes there are earphones where latency is not mentioned, how ever latency be whatever it is, just if you make sure it is either 40 or Below 40ms, your tws could give you extreme gaming experience with almost negligible lag. Do look for the latency, Also, after that, there is sound quality, so enemy footsteps may be without delay, but would be difficult to determine which direction he or she is coming is sound quality is poor or cheap. You could also look for neck band Bluetooth earphones. Else wired are still so far the best for gaming. Rsdt is upto you. Hope this helps.
Luck-è
I have already bought buds 2 and it was nicee 🙌 no complaint
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that the Samsung Buds sound better and cancel more noise than the Google Pixel Buds Pro. It also happens to be on our best noise-canceling wireless earphones list. The Samsung Galaxy Buds 2 Pro earphones earbuds are comfortable to fit and feel better.
