abhijitvinu
11-18-2017 09:58 AM in
Why is their a error message popping up for PROCESS SYSTEM NOT RESPONDING. It happens when I try calling. I try calling from Sim 1 but the phone doesn't respond and after few trys their is some lag and the call connects through Sim 2 automatically. The message then pops up of PROCESS SYSTEM NOT RESPONDING. WITH THE OPTIONS WAIT/CLOSE. It is happening 3-4 times in a day atleast. How can we remove this error.
5 Comments
Devv_007
11-18-2017 01:59 PM in
Do a hard reset through recovery mode.
admin_
11-18-2017 05:03 PM in
Thanks for being with Samsung and sharing your concern. We would like to inform you that please follow the steps below to resolve the issue related to downloading:
Navigate to apps >> Settings >> Apps >> Concerned app >> Clear data & Force stop.
Be sure to hit ♡ when you find an answer that works for you.
Ammy302
11-18-2017 07:08 PM in
https://m.community.samsungmembers.com/en_IN/view/199301?projectId=0&meta=
ShlokF54
01-19-2024 12:21 PM in
It is not app specific...
Yash2523
11-20-2024 11:17 AM in
I had the same issue with my S22. I went to the service center and they changed the software multiple times. But the issue still happens. I contacted the customer care but they said it's chargeable as out of warranty.
They also mentioned that I was the first one to report such an issue so they cannot confirm that this issue was due to the software update. Samsung has to take responsibility and provide us an patch update with bug fixes that actually solves my problem otherwise they have to take responsibility and change the motherboard without taking a single penny from my side as it was purely due to their software update which immediately caused my phone to crash.
