08-25-2024 09:22 AM (Last edited 08-25-2024 09:24 AM ) in
Galaxy S- Mark as New
08-25-2024 09:29 AM in
Galaxy SThe issue should resolve itself within the next few days as the phone learns your usage patterns.
08-25-2024 10:26 AM in
Galaxy SAllthough exynos is also there to blame.
Use breathable covers.
Turn off location when not required and keep optimizing it.
08-25-2024 02:33 PM in
08-25-2024 07:38 PM in
Galaxy SDear Samsung Member,
As per your query, please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
08-27-2024 07:50 AM in
08-29-2024 09:27 PM in
08-29-2024 09:33 PM in
