07-09-2025 09:08 PM in
Galaxy S- Mark as New
07-09-2025 09:14 PM in
07-09-2025 09:41 PM in
Galaxy Shttps://r2.community.samsung.com/t5/Galaxy-Gallery/Competition-Best-Photography-Challenge/td-p/20059...
07-10-2025 11:19 AM in
07-09-2025 09:44 PM in
07-09-2025 09:45 PM in
07-10-2025 05:25 AM in
Galaxy SOpen Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
07-10-2025 08:50 AM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
07-10-2025 09:09 AM in
07-10-2025 11:44 AM in
Galaxy SPlease kindly look into this matter as millions of Indian users using this device and many new customers are adding day by day.
I hope samsung will not disappoint Indian customers .
