One UI 7 Update Problems – AOD, Keyboard Popup, Battery, Gestures
(Topic created on: 05-13-2025 09:13 AM)
xebecyeager
Complete List of Issues (S21 FE – Android 15 / One UI 7)
1. Battery Drain:
  • Noticeably faster battery consumption after the update.
2. Always-On Display (AOD) Issues:
  • Strange notification icon showing in the upper-left corner.
  • Charging animation appears off-center, slightly to the left of the screen.
3. Autocorrect UI Problem:
  • In dark mode, when tapping on a word, the autocorrect popup appears in light mode
  • Text and background both are light-colored, making it hard to read
4. Swipe Gesture Issue for Notification Panel:
  • Cannot swipe down from middle-right side of home screen to open the notification panel.
  • Works only from top-left or top-right corners.
Note : After the update, I've factory reset my phone.
 I like the animations though.
16 Comments
Ujjwal9
I could say battery drain would be eminent as this as a major update and it takes time for device to adjust. Others I haven't noticed that much.
cs_member10
Dear Samsung Member,
We appreciate you taking the time to share valuable comments, and taking your valuable feedback. We are continuously working to make our products better and more efficient.
Kindly share the log file regarding issues. Also, share video clips and images for better understanding. This will help us to further investigate and resolve your issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
xebecyeager
reser
Reset ALL
xebecyeager
Already did my friend, just after the update...I've mentioned that in Note too
reser
Reset
👏7
