Noise Cancellation for calls
(Topic created on: 06-07-2024 10:55 PM)
BitSingh
Hi, please help to understand how noise cancellation work during phone call.
5 Comments
jay666
Which phone are you using currently?
BitSingh
S21 FE
Umangmathur
It cancels all the atmospheric noises around you and focuses on what are you saying .
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to activate the noise canceling feature. when this feature is turned on, it will block out noise in the nearby area, so you can be fully immersed in your music. If you ever need to be aware of your surroundings, simply turn off Active noise canceling.
Note: This feature is not available on the original Galaxy Buds or the Galaxy Buds+.
Follow any of these methods to use the active noise canceling feature.
Method 1- Using touch-and-hold: To enable Active noise canceling on the Buds themselves, simply touch and hold one of the earbuds while you're wearing both of them. You will hear a beep, indicating that Active noise canceling has been turned on. To turn it off, touch and hold one of the earbuds again. You’ll hear a different sound when Active noise canceling is disabled.
Method 2- Using the Galaxy Wearable app:
Step 1: To turn on the feature with your Galaxy Buds2, first insert both earbuds into your ears.
Step 2: Open the Galaxy Wearable app and then tap Active noise canceling. You will hear an activation sound when the feature is turned on.
Step 3: To turn off the feature, simply tap Active noise canceling again.
However, If you have other concerns regarding Samsung products kindly feel free to get in touch with us.
arunimaaru8606
How to do noise cancellation for samsung gallaxy a 15
