Network problem
(Topic created on: 09-14-2024 10:35 PM)
nageshwardhuriya
Samsung s23
5G switches to 4G all the time
14 Comments
bro 5g network ready in my city
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that 5G network service may not be available depending on the network conditions of your mobile network service provider even though you are in the 5G service area.
Regarding this, the mobile network service provider will continuously improve the network quality of 5G service through gradual network coverage expansion going forward. And, the 5G devices use in conjunction with LTE and 5G networks and support the high-speed processing of large data, which may result in increased battery consumption and higher heat generation compared to LTE devices under the same conditions.
Also, when you use applications that require more power for extended periods, the device may heat up due to increased battery consumption as well. If the 5G device heats up to a specific temperature during use, the algorithm to prevent the device’s overheating operates, and accordingly, the maximum performance of the device may be limited and the network signal changes to a 4G network.
This is a normal operating condition to assure continuous device performance.
In this case, please wait for the device to get cool down for a while and then use the device again. If the 5G device gets cooled down to a specific temperature, the device will connect to the 5G network again.
However, if you are facing more then issue as usual kindly visit this mentioned link to resolve your Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
3w63w74e
Same problem while gaming
I'm normal using
Sugam_
Smae issue I'm facing all time when I'm on video call
