Network Problem Show No Network
(Topic created on: 10-14-2025 09:42 PM)
Manish881
Last 2 days my mobile network is show no network in a day 10_15 time
S24 ultra month old
8 Comments
BiRdMaN
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists then send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
Yogender828
I think you have to port india's fastest network airtel.
Manish881
Bhai airtel or jio two sim hai...network dono ka chala jata hai 😂
Yogender828
Manish881
Socha to tha ki aacha hoga lekin ganta aacha...iPhone mai passnd nhi krta or samsung ka liya to pange pe panga..soch to s26 ki rha tha lekin ab nhi luga
Manish881
I try many options but not solve not update..Hang Problem
01aadit
Ek baar all network settings reset karke dekho syd sahi ho jaye.
cs_member10
Dear Samsung Member,
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
