Network issue with S22 Ultra OneUI 6.0
(Topic created on: 02-15-2024 06:02 AM)
gopmrx
After updating to OneUI 6.0 my both Airtel and Jio shows network issues all the time. I always have no service problem.
I have this issue on both the sim cards Airtel (Sim 1) and Jio (Sim 2). I updated Airtel SIM card as well. Anyone else experiencing the same?
Update: 16/02/2024 at 13:30
I started using primary sim Airtel as eSIM. Issue not resolved. Also, I noticed this problem where signal strength is little lower than high signal areas. I get network only where signal strength is high or complete 5 bars.
I can not access the band selection menu when key input Q0000. Nothing happens...
gopmrx
Yes
b1ttu
Flight mode try kro & reset phone.. (if possible) ya fir.. sim nikl kr insert kro
gopmrx
Not working
b1ttu
fek k thod d bc ..
swapnil
Same issue on my s22 ultra samsung doesn't care...i will never buy Samsung again
gopmrx
I feel the same bro
cs_member10
Dear Samsung Member,
Kindly check the device in a different location/network coverage area.
Check device network mode settings: Settings> Connections> Mobile networks> network mode SIM1 or SIM2> Select network mode(set device network mode as 5G/LTE/3G/2G (auto connect) mode.).
Check network operator settings: Settings> Connections> Mobile networks>Network operators> Select automatically> OK> Registered on the network.
Note: We recommend setting device network operators as automatically.
Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
Reset settings: Settings > General Management > Reset.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
vks13
Same problem with my s22 ultra
pn12345
Same problem,it is software issue,samsung should acknowledge it
