Network issue with S22 Ultra OneUI 6.0
(Topic created on: 02-15-2024 06:02 AM)
gopmrx
After updating to OneUI 6.0 my both Airtel and Jio shows network issues all the time. I always have no service problem.
I have this issue on both the sim cards Airtel (Sim 1) and Jio (Sim 2). I updated Airtel SIM card as well. Anyone else experiencing the same?
Update: 16/02/2024 at 13:30
I started using primary sim Airtel as eSIM. Issue not resolved. Also, I noticed this problem where signal strength is little lower than high signal areas. I get network only where signal strength is high or complete 5 bars.
gopmrx
Not working
Mayur000
Using service menu, user can remove or choose bands of 2g, 3g, 4g, 5g,
For more settings try key input code Q0000.
Plz remember all default settings or not it down if you did any changes,
Just find band selection from it, and choose bands.
Mayur000
gopmrx
It will not work. Because it's a software issue.
This is my Sim1 . Key input is not working for me. It is really annoying, I can not use the phone, I don't think that it is a hardware problem...
gopmrx
It's a software issue. Samsung should fix this.
Mayur000
gopmrx
It's a software issue. Unless Samsung pushes an update, this phone is not useful for calls/internet.
Mayur000
For second sim
Mayur000
Just choose select all bands and then apply itScreenshot_20240216_132042_Service mode RIL_1000005098_1708069901.png
