Net connection problem
(Topic created on: 02-16-2020 08:28 AM)
impatel
Every morning i need to put my s10 in flight mode or data connection on another sim. I m turning of data every night. Also scheduled auto restart every night. Since, handset bought facing this net problem in the morning..
Is it common for all ?
3 Comments
immi007
no, check at Samsung store.
Samsung_Support4
Hi there,
Kindly follow the mentioned steps to resolve the issue in your device.
1) Check Network mode and set it to Auto Connect. (Settings > Connections> Mobile Network> Network mode> Select LTE/3G/2G auto connect).
2) Search for the Network Manually via following path (Menu> Settings> Connections>More Networks> Mobile Networks> Network Operators> Select Manual Search).
3) Perform the reset network setting (Go to the settings>>general management>>reset>>reset network settings).
4) If still issue persists then we would suggest you to contact your service provider.
For further assistance, kindly visit the nearby Samsung service center for the physical inspection of the device. The address details of Samsung Service Centers are available at our website. Please click on the link mentioned below to get more information:
http://www.samsung.com/in/support/servicelocation/
Regards,
Team Samsung Members
impatel
Solved.. actually problem was in do not disturb. I scheduled on during night 10pm to 7am. After turning of do not disturb, now not reqd to change flight mode or data connection on another sim.
Samsung pls chk your DoNotDisturb option.
