Navigation bar side not work sometimes in s24 ultra
(Topic created on: 01-30-2024 10:37 PM)
namitaduggad
Recently I bought new samsung s24 ultra having issue using map navigation bar.
7 Comments
nirmalroot
Bro go to settings display navigation button and select buttons and exit
namitaduggad
I tried that before but the problem occurs suddenly after selecting both option of navigation bar. Now it works normally but I worried about later.
Itsmyself
Expert Level 3
What is your review of S24 Ultra?
namitaduggad
I didn't use it full but for long distance camera and videography It works fine. Overall it's 9/10mobile. 20240127_211143_1000012686_1706370107.jpg
Itsmyself
Expert Level 3
Thanks a lot 🤝
cs_member8
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
If the issue still persists kindly report the problems of your Samsung smartphone with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
namitaduggad
Sir I bought new device 2days ago. If such kind of issue happens within 2days of bought what happen in a year. After buying premium mobile and this kind of error happens then normal smartphone is better than this.
