NOT able to send sms using my s22 ultra
(Topic created on: 11-19-2023 12:14 PM)
Guru-lko
I am receiving sms but not able to send any. Currently using jio network. I am having a working sms plan.
Please help.
6 Comments
Devv_007
Check the Message center number in its settings.
Guru-lko
It is 1234
Devv_007
Which state?
Open this website and put the message center number of your state in it and check again.
https://tricksdev.in/jio-message-center-number/
Guru-lko
Thanks @vicky455
AJAB_MORIA
Are you using tow sim cards ?
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Check the message center number: Messages>More (Three dots)> Settings>More settings> Text messages>Message Center>Message center number and Tap on OK.
Note: Contact your service provider to get the correct message center number.
Clear the messaging app's data: Settings> Apps> Messages> Storage> Clear data>OK> Message app data cleared.
Note: kindly contact your network service provider once to make sure there is no issue from their end.
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
