My S23 ultra is hanging, and auto restarts while using Instagram.
(Topic created on: 04-06-2025 12:48 AM)
Ani1883
Is there anyone facing this issue 🤔
16 Comments
Same here, man. Actually, it's an Instagram glitch. Download one of the previous versions and do not update to the latest version. It happened to me twice.🤣🤣
rohits23
Same here in my s23
Vinay_K
I thought i was only one having this issue
Good to hear i am not alone
anil7280
Same here brother....what was the solution
Use older version brother
Jahnvi23
Same here in my s23 ultra.. whats the solution for this???
atharva1505
Same happening to my s23. Does anyone know it's solution?
cs_member10
Dear Samsung Member,
As you have mentioned that you are facing the issue with third party apps and if your device other application working fine with mobile internet, So we would request you kindly contact the respective helpline they will guide you regarding the exact information regarding this.
However, If still facing the same issue, kindly share the log file. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
goodthings
