Move or Copy problem in samsung My Files application.
(Topic created on: 07-19-2024 07:54 AM)
TanujB
I have connected One Drive to My Files but I am not able to move any file to One Drive in My File application.
It shows an error as "Couldn't move files".
While I could share/upload the file to One Drive application directly.
Does anyone else facing same problem or anyone have a solution for it?
Screenshot of the notification after move failed.
3 Comments
Oldy4756
I haven't encounterd this but Check if my files is updated from Galaxy store .
And also check if this is enabled.(Screenshot)
Clear data and cache of my files app .
prakshraja
Beginner Level 4
Screenshat
cs_member9
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
