Color pallet problem
(Topic created on: 05-19-2025 06:35 PM)
pk246
When we apply color pallet to app icon then it is not working for all application.
Dear samsung developer please look into this matter and fix it.
For reference screenshot is attached....
3 Comments
AmitSingh90
It's not a problem some 3rd party app doesn't support colour pallet
pk246
Ok
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
