a week ago in
Galaxy S- Mark as New
a week ago in
a week ago in
Galaxy SDear Samsung Member,
Reinsert the Memory card: To remove the memory card follow the below steps:
Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step 4: Insert the tray back into the tray slot.
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information.
Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
Restart the device and check.
Note: If you use the Fingerprint security feature, the phone will require your backup password to unlock after rebooting.
Restart the device. Path: Press & hold the power key> Restart>Restart.
Kindly format your Memory card once.
a week ago in
Galaxy S![](/skins/images/47A38F389A2746082498E97CDFD8C643/responsive_peak/images/icon_anonymous_message.png)
