March update for S22 Ultra causing major battery drain
(Topic created on: 3 weeks ago)
hsam5
Up till now everytime I update the monthly security update my battery keeps fluctuating and gets worse sometimes better, 2025 March security update for S22 ultra is too bad ...can't even seem to get 3-4hrs of SOT on normal settings with fhd+,120hz,normal brightness and sound , don't really run big apps and yet to much battery drain , the battery life is still good and I have ensured to always follow good battery health tips , why buy a flagship phone and suffer, even midrange phones seem to get better battery than I do this month ....disappointed with this experience pls help samsung, april update noe scares me only one ui 7.0 can fix this hopefully 🙏 🥲🫠
2 Comments
mitultanti
Same problem my s22 ultra
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
