Major problem with android 14
(Topic created on: 12-17-2023 08:47 AM)
Shubham_sony
After updating my s23 ultra to Android 14......sms sending feature is permanently disabled by samsung.....you can't verify your number in secure folder thats means one device one account.....you can't use 2 applications of phonepe...gpay ..paytm or any other banking application which require otp to verify. It is a very major problem with android 14...is anyone facing the same problem?
13 Comments
Shubham_sony
see what samsung team replied regarding this.
srikantaa420
Yes, bro. This vital problem all Samsung device users.
Shubham_sony
see what samsung team said about this
somanath_sahu
I'm seen that same problem with m34& f34 user
Shubham_sony
it's not a problem of s23 or m34 all users which are on android 14 one ui 6 is facing this issue. report this issue to samsung
iamrohitkm
I think 2 apps of the same banking can not be used as dual messenger.
Shubham_sony
in secure folder you can use every app
Shubham_sony
i am using it before updating to one ui 6
