Low speaker volume on Samsung Galaxy s24
(Topic created on: 06-29-2024 01:37 PM)
rohan_thatsme
I bought new samsung s24 three days back. Media volume of my phone's speaker is very low. Whenever I watch movie or web series over OTT apps I have to keep media volume full but still the speaker volume is low compared to other phones. My sound settings are as follows. Equalizer is set to JAZZ and Dolby sound effect is set to AUTO. Please help this is very annoying and disappointing to have such an issue after spending so much money on a flagship phone
5 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear SoundAlive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search SoundAlive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
In case the issue still occurs, kindly report the problems with a log file. Also, share video clips for better understanding. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
rohan_thatsme
I have tried this. It looks like this is an issue with my samsung galaxy s24 device. If I keep equalizer in any mode other than normal mode volume output of speaker is very low.
rishuraj1427
Beginner Level 3
My spekar very issue
