Low call volume from Helmet bluetooth device
(Topic created on: 4 weeks ago)
rounakD
Beginner Level 4
Hey all Rounak this side,
I'm using BluArmor HS1 helmet bluetooth headset with my helmet. The audio volume is perfectly fine but the moment I switch to call the volume decreases drastically. Calling works perfectly fine when connected with an iPhone or may be some other android device. Have not tried with any other Galaxy S device though.
Does anyone has any solution around this?
cs_member10
Dear Samsung Member,
1. Reset App Preferences: Settings > Apps > Tap on More option or on three dots at the top right corner of the screen > Reset App Preferences.
2. If the issue is not resolved by above step, then: Clear “Paired List”: To clear tap on “Settings” option along with the paired device > Unpair.
3. Try and connect your device with another device:
4. If the issue is still not resolved, then “Clear cache and data” of Bluetooth app:
Go to Settings > Apps > Filter and sort > Show system apps > OK > Search apps > type ""Bluetooth"" > Tap on ""Bluetooth"" > ""Storage"" >""Clear cache""
Note: Clearing the app cache is like cleansing your apps. It will get rid of residual files that could slow down the app.
Tap on ""Clear data"".
Tap on ""OK"".
Note: Clearing the data will reset the app to factory default settings. Any personal settings saved on the app will be removed.
5. If the issue is still not resolved, update software:
Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
6. If the issue is still not resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
