Resolved! Solved
Low brightness is not working on lock screen
(Topic created on: 11-05-2024 10:52 PM)
S21FEBoss
I am using S21 FE 5G SD888, The low light brightness is not working when phone is locked and your are going to unlock.
Required to fix it.
2 Solutions
If issue resolved, please share your feedback and mark this as Resolved by pressing on three dots.
5 Comments
Toggle of the setting of brighten screen on lock screen
S21FEBoss
Thanks buddy
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
