Light and Fingerprint Sensor Visible on Display
(Topic created on: 04-17-2023 04:03 PM)
akshayjumde
Any body faces light and fingerprint shown on the
display on galaxy s23
4 Comments
AagyatPrani
That problem is know as screen burning issue
I will recommend you go to service center if you got your device under warranty
Sid_Karna
But this seems to be indoor!
Sid_Karna
I have never experienced this indoors(or even outdoors because I always use darkmode).
What did you do? Did you visit service center?
